All stock on the DemonStock A body spring locations? Quarters rolled or trimmed?
What size tires are you wanting to run?
That 2007 Magnum R/T has a 5x115mm bolt pattern, it's not the same as the 5x4.5" pattern on that B-body rear axle (5x114.3).
I know that the rear end is wider so may some nice 17 x 8 with 6 " back spacing
