Correct Position of 72 Duster Rear Seat Belts
dust44d
What's An A Body ??
Rochester,MN
Could someone post a picture of how the rear seat belts on a '72 Duster are correctly installed/positioned?2 of them are short belts wth the latch and the other 2 are retractors.Thanks for the help!!
heres my 71 Dart. I just put them in and believe them to be correct. Should be the same for your Duster.
OK,that helps some.Does anyone have a picture of how the belts are bolted to the floor board under the rear seat?Thanks!!
Here you go, from my '72 Duster...
C
Mine has 2 belts going to each if the center bolts. A male and a female belt on the pass side and to female belts on the driver side. Once belt on each side has a bend to it were the bolt passes through. That one goes to the floor while the flat on gets stacked on top of it.
I can pull the seat up and get a picture if you need it. Its not really installed yet, just sitting there.
That's exactly what I needed guys.Thanks again for the help!!
