Dennis Gerard
Just got my Barracuda back from body shop and won't start, relay clicks when you turn key, is the a way to check starter with out pulling it?
yes new battery cable on it!Have you check the battery connections to make sure they are clean and tight? And the battery voltage?
Very easy to test starter. If you want to avoid removing it. Which I don’t see why you would because it’s incredibly easy to do so. Take a set of jumper cables. Hook them to the battery and on starter end ground black cable anywhere on starter and as soon as positive touches the big terminal on starter solenoid. The starter should spin. If not the starter needs replaced or rebuilt with new brushes. Easy to do. If the solenoid clicks when turning the key. Solenoid is good and doing it’s job. It’s easier to test starter removed from car. But, You can do it either way.
Very easy to test starter. If you want to avoid removing it. Which I don’t see why you would because it’s incredibly easy to do so. Take a set of jumper cables. Hook them to the battery and on starter end ground black cable anywhere on starter and as soon as positive touches the big terminal on starter solenoid. The starter should spin. If not the starter needs replaced or rebuilt with new brushes. Easy to do. If the solenoid clicks when turning the key. Solenoid is good and doing it’s job. It’s easier to test starter removed from car. But, You can do it either way. Good chance your battery is no good. Learn how to properly test a car battery. Just because it holds a charge doesn’t mean it’s any good. It might have a dead cell. Easy to test for that too. If the battery voltage dive bombs below 8 to 9 volts after you verified it holding a charge of 12 - 13 volts. The battery would have a dead cell and is no good. This can happen to newer batteries too.
it's dead won't turn overCheck to see if the coil has both wires connected to it as well. If someone forgot those wires or they came loose. It won’t start.
battery is new took it out of my other car!The only way to know if the battery is capable of starting it is to put a volt meter on it and then try to crank.
If the volts drop under 10.5, bad batt. If the voltage doesn't change, wiring issue. You should have 12.4-13 volts at rest.
New doesn’t mean squat. You have to test a battery when it’s under load or power being drawn from it. This is how you test for a dead cell.battery is new took it out of my other car!
