Cuda416
98 5.9 from a Durango and a 904 from a V8 car going into a 65 valiant..
1. Car came with a 3 speed manual with a ball & trunnion style drive shaft and a 7-1/4 rear. What is a suitable replacement for the dive shaft? My understanding is the 66 had a slip yoke style, will that work? We'll eventually swap out the rear for an 8.8 and will obviously need to shorten and re-balance whatever drive shaft is in at that time but in the mean time, what are some good options?
2. Radiator and Water pump. We're changing the front to LA style. The lower connections all appear to be on the passenger side, but the v8 radiators are seem to have the bottom connection on the drivers side. What obvious thing am I missing?
3. Torque converter. The one we got with the 904 has what looks like a small weight welded to one side, so i am assuming this is for a typical externally balanced engine with a neutral flex-plate. If that's correct, then I believe I cannot use the factory magnum flex-plate and need to replace it with a neutral unit, ya? Not sure how to identify the TC so any tips there will help.
Any and all tips/comments appreciated.
Thanks
-C
Here is an example Valiant (65-66) Radiator
Thanks
-C
