Should have mentioned this info is 67 dart, but I suspect it is the same for other years and body
The glass, (plastic?) dome pulls out from the inside of the car, then the bulb socket pulls out of that.
Both use spring fingers to hold onto each other and the plastic side panel.
Dome in plastic side panel.
Bulb socket.
The bulb is a 90
The first time I did this i burnt out the bulb.
What I found is put plastic side panel in place, pull the socket through the hole, with door shut (or door switch in door closed position, lights off) put bulb in socket, then put bulb and bulb socket into the lense then push the lense into the plastic side panel.
Something to note.. if you remove the "L" shipped plate from the bottom of the plastic side panel. The "L" bracket is to the inside of the car and the screws are to the outside
