hoosierdaddy
I'm getting ready to do my Magnum swap and I decided to use my V belt set up so I installed my early timing cover and when I did I cracked the left front lower bolt hole where the oil pan bolts through . The bolt is tight but should I be concerned about an oil leak ?
