Cracks around metal at base of windshield
Mopar Body and Trim
  1. briwill70
    briwill70 Well-Known Member
    120
    40
    Feb 2, 2020
    Portland, Oregon
    Local Time:
    9:33 PM
    I've got a 65 Dart. Car is rust free and has the original paint as far as I can tell. There are small cracks in the metal forming near the base of the windshield and I also noticed one inside the driver's side door jam below the windshield area. Is there a factory seam there or is this something else?
  2. George Jets
    George Jets 1967 Dart 2 Door FABO Gold Member
    4,798
    6577
    Jan 18, 2019
    Farmington MN
    Local Time:
    11:33 PM
    Might be flexing from the driver opening the door and it getting caught in the wind flexing the hinge pillar and stress flexing the lower windshield frame.
    I would say hang onto those doors when you are opening them, and it probably won't go any farther.
    Those are called battle scars from it coming through 50 years of time . . .
  3. Lee Robinson
    Lee Robinson FABO Gold Member FABO Gold Member
    7,015
    469
    Aug 23, 2009
    El Dorado Hills, Ca.
    Local Time:
    11:33 PM
    There is a leaded seam at the outer parts of the upper cowl and the windshield pillars. The lead won't rust, but the metal underneath can.
    There maybe water infiltration at the windshield pinch welds causing rust and cracking. Removing the windshield and gasket would be required
    to really see what's going on. The lead is also on the vertical edge of the cowl from factory metal finishing, that can be seen when the door is open.
    That is my take anyway.
    • Like Like x 1
    • Agree Agree x 1
    • Alaskan_TA
      Alaskan_TA Well-Known Member
      5,956
      4378
      Nov 12, 2004
      PA
      Local Time:
      12:33 AM
      The A pillars do have seams with filler in them where they attach to the cowl & cracks in the filler over time are normal.
      • Like Like x 1
      • Tooljunkie
        Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
        18,697
        19929
        Jul 22, 2017
        Manitoba
        Local Time:
        11:33 PM
        Yours is probably thin, rusted from the underside like mine was. At some point the cracks were brazed. I cut it out and patched it. 194F3314-7619-4A1D-88F5-1A29D255B2CD.jpeg 5B56BD43-5A25-45CB-8803-318C66996C66.jpeg
        • Like Like x 1
        • briwill70
          120
          40
          Feb 2, 2020
          Portland, Oregon
          Local Time:
          9:33 PM
          • Like Like x 1
          • Demonic
            Demonic Well-Known Member
            1,545
            1223
            Mar 21, 2015
            Maryland
            Local Time:
            12:33 AM
            I had a similar issue once, but at the top of a windshield. Melted out the lead, welded, filled, fixed.
            • Like Like x 2
