[SOLD] Crane 1.5 Gold Roller Rockers plus!!
ns1rm21
Hello Everybody.
What we have here today is a very nice used set of Crane, 1.5 Roller Rockers. They will fit Small block Mopar heads. These Rockers will fit your 273, 318, 340 and 360 "LA" style engine. These will not fit "Magnum" engines, W2, W5, W8 or W9 heads. They will fit standard Edelbrock heads and anything that can use a stock stamp steel rocker.
I got these rockers in a running 340 engine that I just purchased. They are in wonderful shape with very little wear. They also come with rocker shafts, hold downs and new Grade 5 mounting bolts. As you can see in the pictures there is very little wear.....there is some markings on the shafts and inside the rockers themselves but that is typical to rockers with three hundred +/- miles on them.
An added kicker is I'm throwing in a set of Pushrods that can be used with any Hydraulic, felt tappet cam. These pushrods cannot be used with any roller lifters, only standard lifters.
One of the rockers does have a mark where it looks like the adjuster came loose and was touching the bottom of the rocker but there was no real damage at all. I checked the threads in the rocker and the adjuster and all is very safe to use.
So this is everything that you need to put roller rockers on your Small Block Mopar. You get the rockers, shafts, hold downs, bolts and pushrods. All this retails for over $620.00 through Summit Racing but I’m going to sell it for $385.00 plus $32.00 shipping anywhere is the lower 48 states. I'm in Simi Valley, CA. I can take PayPal or a personal check but the check needs to clear before I can ship. I’m giving You guys first shot at it before I put it on Ebay so PM me if interested.
Thanks again, Troy, Simi Valley Ca.
