I bought a rebuilt short block and was told the crank was .020 over and the rods were resized to .020 over. I do have the paperwork from the machine shop so I know it was done. I plan on checking the rod and main cap bolts torque just to double check them. Should I use some plasti gage and check the oil clearance also ? just to make sure and what should the clearance be?
Thanks
(72 stock 318 for street use)
Thanks
