CRANK WOBBLE!! Updated, found problem
Forced Induction Mopar
  1. Coyote Jack
    Coyote Jack Member #55, I'm old FABO Gold Member
    8,518
    2509
    May 22, 2004
    Baxters Corner N.B. Canad
    Local Time:
    9:45 AM
    The car has not been working the way I like it so I did a little investigating. I put on my pulleys to get 10 to 11 lbs of boost and went for a drive. Everything seemed normal until after I gave it a good hit. Nothing to extreme just wide open until after I was in 2nd gear. After that it was like it was down a cylinder. I checked all cylinders and I am getting fire using the water on the header tube method. I started looking around with the car idling and I noticed a wobble in the crank pulley. Is this normal or do I have a real problem? I have a video of it but I can't upload it to the site.
    Jack
  2. Coyote Jack
    8,518
    2509
    May 22, 2004
    Local Time:
    9:45 AM
    I think this will work. Here is a link to the video.
  3. replicaracer43
    replicaracer43 Grumpy Old Man
    4,323
    3131
    Oct 10, 2008
    Local Time:
    7:45 AM
    Hard to tell from that, but it APPEARS the pulley is what is wobbling, ballancer looks to be running true...hard to say without being there in person.
    • Agree Agree x 6
    • RustyRatRod
      RustyRatRod Bla de blizhibliz de blatde blizi bla bla FABO Gold Member
      61,610
      33561
      Jun 7, 2010
      Georgia
      Local Time:
      8:45 AM
      I agree. I think the pulley is all that's off track. At least it appears that way.
    • Coyote Jack
      8,518
      2509
      May 22, 2004
      Local Time:
      9:45 AM
      Unfortunately that was the best video I could get. The balancer is moving just not as much as the pulley. I am going to take the pulley off tomorrow and check the balancer bolt and stick another pulley on there and check it again. Kind of scared the crap out of me when I saw it.
      Jack
      • Like Like x 1
      • ratvon
        ratvon Well-Known Member
        362
        42
        Aug 21, 2010
        central ohio
        Local Time:
        8:45 AM
        Take the pulley off see if it still wobbles
      • crackedback
        crackedback FABO Gold Member FABO Gold Member
        18,608
        2901
        Aug 7, 2005
        92201
        Local Time:
        5:45 AM
        crank might be broken or cracked at snout or right behind the first main.
        slow the video down to .25 speed. easier to see the balancer wobbling.
        • Agree Agree x 3
        • Like Like x 1
        • Demonic
          Demonic Well-Known Member
          1,316
          1032
          Mar 21, 2015
          Maryland
          Local Time:
          8:45 AM
          Do you have a dial indicator and a long stand? Check the crank snout with the balancer off. Might have to spin with the starter, or run the bolt in w a spacer and turn by breaker bar, the better way.
        • Rolling_Thunder
          Rolling_Thunder Rolling Thunder
          106
          22
          Jun 27, 2005
          Los Angeles, CA
          Local Time:
          5:45 AM
          I would buy a dial indicator (if you dont have one) and remove everything down to the crank snout... then turn the crank by hand and track if the snout is bent - this would show something wrong with the crank... if it shows true then it's obviously somewhere else... put the balancer back on and repeat the process... then add the spacer... then the pulley... checking each piece as you go --- itll narrow down where the problem is.
          • Like Like x 2
          • lilfontleroy
            lilfontleroy annoyinglilLeroy FABO Gold Member
            2,055
            1877
            Nov 20, 2017
            USA
            Local Time:
            7:45 AM
            aren't the OEM balancers prone to some level of failure at the bonded elastomer where the inner and outer rings are "together"? I wonder if it is failing on you and would a Fluid Damper or ?? be a better option?
            • Agree Agree x 2
            • Like Like x 1
            • Coyote Jack
              8,518
              2509
              May 22, 2004
              Local Time:
              9:45 AM
              Unfortunately I didn't get at it today. More pressing matters came up, but I will get at it tomorrow.
              Jack
            • Houseoffubar
              Houseoffubar Well-Known Member
              45
              33
              Jun 17, 2020
              Puyallup Washington
              Local Time:
              5:45 AM
              Good call, at 50 and especially 25% speed, the balancer is clearly moving a lot!
            • pishta
              pishta I know I'm right....
              17,573
              7157
              Oct 13, 2004
              Tustin, CA
              Local Time:
              5:45 AM
              Youtube troubles lately, any one else see this?
            • '63GT
              '63GT Well-Known Member
              1,075
              1030
              Jun 9, 2018
              Turlock, CA.
              Local Time:
              5:45 AM
              As Leroy stated, the elastomer gives out over time one the OE units, and even the performance counterparts require 'rebuilding' to replace the O Rings in the dampers.
              Which is why Fluid Dampers are so popular.
              BTW, if this is the case, and the damper has slipped, the wobble will grow over the length of the pulley. Basically exaggerating the runout.
              The best way to confirm the issue is to put a timing light on it to see if your timing is off from your normal setting.
              Also too, look all the way around the damper to see if rubber is pushing out between the hub and outer ring.
            • RustyRatRod
              61,610
              33561
              Jun 7, 2010
              Georgia
              Local Time:
              8:45 AM
              I'm thinking the same.....I just didn't wanna rain on Jack'a parade.
              • Like Like x 1
              • RustyRatRod
                61,610
                33561
                Jun 7, 2010
                Georgia
                Local Time:
                8:45 AM
                A dial indicator? Seriously? Take all the belts off, grab the crank pulley and if you can rattle it up and down, side to side, the crank's broken. Real simple. Possibly real unfortunate.
                • Like Like x 2
                • Agree Agree x 1
                • Houseoffubar
                  45
                  33
                  Jun 17, 2020
                  Puyallup Washington
                  Local Time:
                  5:45 AM
                  If you watch the video in slow motion it seems pretty clear the inner balancer is wobbling, making the blower pulley really wobble.
                  Sure looks like a bent or broken crank, especially with the running condition
                • pomonamissel
                  pomonamissel Well-Known Member
                  1,853
                  893
                  May 21, 2015
                  san jose , ca
                  Local Time:
                  7:45 AM
                  if the crank is bent , the pulley is way out there . you won't see it wobble with your eye on the damper , its dial indicator time on the damper and rotate the motor by hand . blowers like to crack crank noses off it starts with a bent nose . and are you sure you damper is not taking a sh....t . la's are known for damper to fail to stay in good shape .
                • Coyote Jack
                  8,518
                  2509
                  May 22, 2004
                  Local Time:
                  9:45 AM
                  Unfortunately, I have not been able to get at it due to other issues around here. Hopefully in a couple of days. I can say with all belts removed the pulley does not move by hand. I will be able to tell more once I take the pulley off and can see the damper better. I will have a look with the timing light today if I can. It doesn't take long to check it. I don't think the crank has broken yet as all cylinders are firing.
                  Jack
                  • Like Like x 1
                  • MiradaMegaCab
                    MiradaMegaCab Well-Known Member
                    1,098
                    664
                    Feb 5, 2011
                    Long Island NY
                    Local Time:
                    7:45 AM
                    Is the crank forged?
                    Is it double keyed?
                    Is that a stock damper?
                    Was the blower belt too tight?
                  • Coyote Jack
                    8,518
                    2509
                    May 22, 2004
                    Local Time:
                    9:45 AM
                    Stock forged crank, single key, stock damper. Blower belt did not appear to be to tight. The only big difference I can figure is that I was running a smaller top pulley and had the boost up to 10 to 11 lbs.
                    Jack
                    • Like Like x 1
                    • Coyote Jack
                      8,518
                      2509
                      May 22, 2004
                      Local Time:
                      9:45 AM
                      I found a few minutes to look at it this morning and also found the problem. SEE PHOTO My only guess is that when I upped the boost the damper couldn't take the extra stress and failed. Of all the things that could have happened this is definitely not the worst. It cracked the timing cover as well, but I have a spare one of those. The crank seems to be running true so I am not to worried about it. Anybody know where I can get a decent damper quick in Canada?
                      Jack
                      • Like Like x 5
                      • Thanks! Thanks! x 2
                      • 4spdragtop
                        4spdragtop FABO Gold Member FABO Gold Member
                        29,111
                        9261
                        Aug 28, 2009
                        Wasting time here
                        Local Time:
                        7:45 AM
                        Glad it was only that Jack! I know Summit has free shipping to us Canucks if you spend $300 US??
                        • Like Like x 2
                        • Thanks! Thanks! x 1
                        • Agree Agree x 1
                        • Divenut
                          Divenut Well-Known Member
                          3,089
                          1396
                          Sep 22, 2011
                          Naperville Illinois
                          Local Time:
                          7:45 AM
                          Real happy to see you got her sorted out man. And not catastrophic.
                          Be well,
                          Pat
                          • Agree Agree x 4
                          • Like Like x 1
                          • Demonracer
                            Demonracer 71 Demon 00 Ram 16 Chrysler 300S 05 Caravan FABO Gold Member
                            3,515
                            1466
                            Jan 31, 2010
                            Cleveland, Texas
                            Local Time:
                            7:45 AM
                            It needs a good SFI balancer Jack.
                            • Agree Agree x 7
