sublimeswinger
SUBLIME Senior Member
What does it mean if your crank is cut 20 under? What kind of power or torque does this give and why would it be done? The motor is a 318
It means the bearing surfaces were cleaned to.0200 under their original size. Means you'll need a 20 over bearing set. No difference in performance.
