injected360
Active Member
For a budget build on a 360 early 80s block whats a good crank, maybe around 700.00 give or take alittle. Is SCAT good? Never bought a after market crank and not sure which one is best for the dollar. your thoughts.....
I want to run around 12.5 to 13 compression a good aftermarket rod and thats why the crank question I have the OEM crank and the machine shop said it was good but I'd like to try to hit 550 or so HP. I've got a lot of homework to do.......
