dbphemi
So i just measured my crankshaft main and rod journals to check for wear and taper .I’m doing a light rebuild with new bearings and rings and seals. I had this crank machined decades ago when i was in high school by a machine shop that is no longer in business. the rods are .030 under and the mains are supposed to be .020 under.
i measured the rods and they are 2.095 which is .030 under the stock spec of 2.125.
I measured the mains a they are 2.4802 . It should read 2.480 at .020 undersized. is .0002 over going to be a problem?
I haven’t measured bearing clearance yet , I'm in the cleaning phase right now but i’d like to know if i need to have things machined.
Thanks!
Thanks!
