daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
Just curious what's the best stroker kit for the 360 MP Magnum crate motor?
Holy Smokes:
If you're going to put a stroker in it, buy a 5.9 out of a junkyard to start with. Save yourself a LOT of money.
Already got roller cam motor complete from top to bottom and front to back with tti's to the tailpipes.
Thanks
Then sell it and use a cheap core from the junkers to build your stroker. With the difference, you'll defray a helluva lot of the stroking expense. All you'd be using from your crate motor is the block and maybe the rods.
