Orionsax7
Anyone have experience with the company Blueprint Engines? I just saw them in Jeg's and visited their site. Engines actually look pretty well made from what I can tell and they offer a Magnum headed, rpm airgap, 408 stoker 360 rated at 395hp/475tq for $3600.
Block:
Seasoned 360 block
Square and parallel decked
Align honed main bearing bore
Cylinders honed on computer controlled machine to within .0002 straightness and roundness
Cylinders are sonic tested for thickness
Rotating Assembly:
New SCAT cast iron crankshaft
Keith Black hypereutectic pistons
Chrysler heavy beam rods
Hastings Moly rings
Balanced rotating assembly
Melling high volume oil pump
Flat tappet hydraulic lifter camshaft
Heavy duty double roller timing set
Cylinder Heads:
Blueprint magnum cast iron heads
Hardened retainers and springs
2.02 swirl polished intake valves
1.60 swirl polished exhaust valves
Hardened push rods
A Ton Of Extras:
EDELBROCK RPM Air-Gap Intake
New chrome "MOPAR PERFORMANCE"valve covers
Brass freeze plugs
Dyno tested and shipped with results
Comes with 24 month / 24,000 mile warranty
Critical Specs:
Horsepower:
395
Torque:
475
I sent em an email asking about their balancing process and what kind of cam they use in it.
-Alex
Block:
Seasoned 360 block
Rotating Assembly:
Hastings Moly rings
Cylinder Heads:
Hardened push rods
A Ton Of Extras:
Brass freeze plugs
Critical Specs:
Horsepower:
395
Torque:
475
-Alex
