Crossmember and floor pans
1969340dart
Porter Texas
Rating - 0%
0   0   0
I need a stationary crossmember for a 67-69 A Body.This is the piece that the removable cross member bolts to.My 67 Dart Gasser project has one but it has some rust in it so I would rather replace than repair.Also need rear floor pans.Mine have some rust in the lower recessed piece.
Thanks
Bobby
Can you take a pic of the floor pan area you need. I have a few pieces that you may be able to patch in.
Are you looking for the main torsion bar crossmember that your trans member drops from?
I believe I have both, just want to clarify.
