Did the offset push-rod help much when porting? Seems most of the gains are in the pocket. No one really talks about the push-rod "pinch" when porting on the J heads.
Thank you for your response.I believe it depends on how much flow you are looking for and if you have enough motor to support that higher flow with your combination. Street motors need to flow only so much to operate low rpm and low speed operation as opposed to race motors that operate at wot in high rpm conditions.
Yes Yes. Probably never did or will happen.It would make for an interesting dyno test.
Build something big enough, capable of making enough power to exploit any possible gains the pinch itself might offer.
Something like an 11-12:1 408/416, .600-ish lift cam, decent single plane intake, nice carb, 1-7/8” headers.
Take a set of TA heads and do a nice port job on them(260+), but don’t make the width at the pinch any bigger than what could be done safely without breaking through the pinch area of a non-TA J head.
Dyno test the motor.
Pull the heads, open the pinch area as much as is easily done without worry of breaking through with the TA configuration(no additional work...... only the pinch area)..... reinstall heads..... retest.
You don't seem to understand or know the answer to my question. I'm not building anything here. Just CURIOUS.Better off with after market aluminum heads or the indy cylinder heads iron ones, forget the name of them. If you must have mopar parts, w2 heads but then they require intake and headers to match. Best stock heads are 308’s. Swirl ports with closed chamber I believe. If you want to move the pushrods in any heads the hole can tubed (expensive). Alterating pushrod geometry is never a good thing, not that the mopar small block has real good geometry to begin with unless you have a 48 degree tappet bore angle R block to begin with.
I agree. It seems the engineers went through a lot of work for nothing other than keeping their jobs by applying changes.I think most gains on most any head is in the bowl area. @MOPAROFFICIAL would be a good one to chime in. He's done a lot of work on stock type heads.
Probably didnt even use a gasket between the ports.I think I understand your question, I don't know the answer. But here is a Glidden Arrow Pro Stock Head. Push rods have been moved.
IIRC ... Glidden ran W2sI think I understand your question, I don't know the answer. But here is a Glidden Arrow Pro Stock Head. Push rods have been moved.
That IS a W2 head.
Correction: that WAS a W2 head. That beast is a long ways past the way it was born.That IS a W2 head.
