is anybody using the accel cut-to-fit 8mm ignition wires on a 318? if so, how do u get the wire in the damn boot? i struggled with it for 30 minutes and couldnt get the first one in.
WD-40 and good set of crimps. The custom ones are always to short or to long for some reason. Might just be me but I know that the shortest wires go closest to the distributor. It's a little pain to have to cut and a crimp but you end up with the exact length you need.
