Would it seem logical that what's good for the LD340 is good for the D48 or LD4B in regards to the Direct Connection plenum mods? I don't know the exact spec but I'm talking about the square notch.
For those that care: 1965 273 2-bbl. Changing to dual point distributor, D4B, Carter AVS 4638SA (1969 340 auto), Commando type cam grind. I will probably keep the 9:1 (?) pistons for now but if it gets opened up you know the 10.5 pistons will go in.
So, from a flow and distribution aspect is what is good for the goose also good for the gander?
