Damaged My Own Trim Rings
dibbons
La Paz, B.C.S., Mexico
Wanted to remove the tire on the rear of the '65 Signet convertible. First had to remove the "baby moon" to access the lug nuts. Tried by hand with a large flat blade screwdriver, nothing doing. That's when I noticed each time I leveraged the screwdriver against the rim, I was leveraging against the trim ring, denting the chrome over and over again with each attempt.
I removed the trim ring and used a hammer along with the long screwdriver to remove the stubborn hub cap. Live and learn.
Look around & find a "hub cap hammer", it has a spool bill for removal & a soft rubber head for installation.
Make your own. Get a long straight slot screwdriver, heat up the end and bend the sucker.
Edited for spelling. :BangHead:
I never smoked until my tasks that required finesse were completed.:BangHead:
Oops. Always take the trim ring off before the hub cap.
