nothingbutdarts
I have a 81 D200 with a DANA 60, the wheel bearing nut is a nylock single nut versus the old two nuts and a lock ring, could someone give me a wheel bearing nut torque spec? I would guess you tighten it to like 150' lb, spin the hub assy., back the nut off then retorque to a very low spec. but, not sure what that spec. would be.
Thank You!
Thank You!
