540dart
Active Member
can i use a dana 60 from a ford f250 and just cut the housing to fit my dart?i well be using aftermarket axles in it.
I would recommend trying to find one from a late 60's lighter duty truck. If it has a limited slip carrier in it, it will be a Powr Lok. And the housing itself is significantly lighter than the larger and later trucks have. It won't weigh down your car so much, be plenty strong, and have a good carrier.
