Dart quarter window molding and side window guard
afazio01
Guys, can you tell me how the window glass is fastened to the frame for the side windows? Is is just weatherstrip adhesive?
thanks
If it is a Dart Sport you have to pull the weather stripping down and there is four phillips screws in the door jam. Then you have to pull the plastic and panel below the window and there is one more screw at the bottom rear of the window by the latch.
Hang10 is correct. Just replaced my seals last week. There is one screw behind the sail panel if it is a Dart Sport. 5 total screws.
