Dart Rear Window Moulding
DDart1972
chris
Southern California
Does anybody know if the window rear moulding is interchangeable with all Dart body styles 67-76? I know that the Dart Sport is obviously different, but I want to know if it's interchangeable between a 2dr, 4dr and a post car.
So am I to assume that nobody knows.....Or is it just a dumb question? The reason I ask is that I need the rear window moulding for my 2dr hdt swinger and there is a 67 and a 74 4 dr Dart in the junk yard with good moulding, I just want to know if it's worth it to grab it.
4 door and 2 door post is same.
2 dr hardtop is different
The 4 door moldings should be a little taller on the sides 1-2".
Ditto what crackedback said on applications.
Also note; my 67 does not have a small screw through the bottom molding at each end. (These were always the first molding clips to rust out)
"Fern" our 75 Dart has a screw approx 1" from each end of the bottom molding.
If you can't find any, we might have some in stock. Yard Dawg usually charges $100.00 + shipping per full set.
Good Luck!!8)
