Dart/Scamp alignment How?
johnparts
Slammed 1
Lisle Illinois
So I was looking at my car yesterday and I was wondering how I would get my alignment heads on the back end. They hold on the edge of the wheel and you need to roll the car back and fourth in order to get the readings yet I don't see a way to get the back on there even with a stock wheel. Anyone have thoughts or suggestions? We have a hunter machine here.
Our alignment heads grab the tire. If you are using hunter equipment you should be able to do a jack up compensation or grab the inner lip of rim. You can put steel wheels on for this also. Ours also has option of doing front wheels only.
Every Hunter machine I've ever used had an option to leave the rear heads OFF. No need for them as long as you know the rear axle is straight.
