Dash assembly
DesertRat
Leading edge boomer
Moses Lake, Washington
Hey all, I am attempting to reinstall my dash in my 67 Notch. I would appreciate any photos any of you have of this operation as it has been a while and I did not take dissasembly photos. Also I ordered a new insturment voltage regulator but it is external and mine must be in the fuel gauge. I found the thread on the conversion but am debating on whether to do it or not as everything worked when I took it apart. Any help and advice appreciated!
DR:coffee2:
The standard inst' panel is a cakewalk by comparison. R&R the rally panel is not something you'll want to do repeatedly. I suggest you do everything you can do before you put it back. Not only the inst' voltage regulator, replace all bulbs and sockets also. Then there's wiper pivot/linkage service, etc... The standard/non a/c climate controller has a plastic piece that is prone to breaking. If all those cables don't operate their doors easily, graphite lube, replace the plastic stem in the controller with brass, anything and everything that will keep you happy moparing for years to come.
