C Challenger Well-Known Member Joined Feb 15, 2009 Messages 366 Reaction score 17 Location hallsville mo Aug 16, 2011 #1 trying to find problem -when hit brake pedal both turn signal lights come on -flip flasher switch and hit brkaes they are off =then turn turn signal on they both come back on the dash help please
Sgt Mopar Well-Known Member Joined Aug 5, 2011 Messages 57 Reaction score 5 Location Dayton Ohio Aug 16, 2011 #2 Wiring problems suck. Maybe a bad ground. did you change anything.
C Challenger Well-Known Member Joined Feb 15, 2009 Messages 366 Reaction score 17 Location hallsville mo Aug 16, 2011 #3 its new car restored-have not had any problems just showed up-i quit drinking 17 years ago but this is making me want a cold one or twenty
67Dart273 Well-Known Member Joined Oct 14, 2010 Messages 60,847 Reaction score 34,478 Location Idaho Aug 16, 2011 #4 As usual, we need to know what you are working on. Is this a 41 Ford or a 53 Studebaker? Also, do the turn signals and brake lights actually work properly, that is, are the dash lights the only apparent symptom?
C Challenger Well-Known Member Joined Feb 15, 2009 Messages 366 Reaction score 17 Location hallsville mo Aug 16, 2011 #5 69 dodge dart--i have find and fix the problem it was a bad flasher switch
Sgt Mopar Well-Known Member Joined Aug 5, 2011 Messages 57 Reaction score 5 Location Dayton Ohio Aug 17, 2011 #6 good stuff. glad you found it.
