dash lights keep blowing fuses
jmoses
Active Member
Ok i got all my dash lights working on my 71 demon but now I keep blowing fuses. I also noticed that when the driver door is open an the interior light came on the dash lights flicker? Does the same with the high beam switch. Any ideas before I take it to an electrical shop.
Thanks
Which fuse is blowing the tail fuse or the instrument fuse?
Start disconnecting stuff in that circuit
Check that you have the proper bulbs
This is a bit of a "trick" circuit and is the ONLY circuit in these cars set up this way
The headlight switch RECEIVES power from TWO sources
1.....headlights ONLY, not our concern
2....The tail / park fuse supplies power for tail and park lights (and cigarette lighter) AND THIS SAME POWER
3....feeds the dash lamp dimmer control. Power comes OUT of the dash dimmer, goes TO the fuse panel and INTO the instrument fuse, usually the smallest fuse on one end of the panel
(Check that this fuse is proper rating, consult your service manual, and that the fuse clips are tight)
The OUTPUT of this inst. fuse then goes out to all dash dimmer controlled lamps on ORANGE wires
This includes any "dash" lamps, in the cluster, radio, heater / AC bezel, I think? the ash tray, the gear selector if it's auto, and factory tach or vacuum gauge on the console.
Has anything been added, IE aftermarket tach, stereo? I would start with those.
I'll check it this week and get back to you. Thanks for the info.
