Dash lights out
BlindSquirrel
Wynnewood, PA
Hello, Guys and Gals,
On the way home tonight, my dash lights suddenly went out. Headlights still work, turn signals work, and heater works, but all dash lights are dead. I will be tracing wiring with a schematic tomorrow, but was just wondering if anyone has an idea on where to start.
Thanks,
Blindsquirrel
Check and wiggle Pin G, a orange wire on the electrical connector on the instrument panel, lower 6 oclock position.
I hade the issue on my scamp, bare wire for the radio shorted a fuse though.
clean the connections on all the wires on the back of the cluster and check the bulbs i did all that and mine started working. and if it has a dimmer it could be going out mine is and it has to be in a sertan spot to light them all up.
First place I'd check is the fuses.
Do your tailights work?
Power for the dash lights actually goes through 2 different fuses. There's a 20 or 30 amp one that includes the tailights, and then a 3? amp one that is just the dash lights.
If there's a problem with the tailights, or if either of those fuses blow, the dash lights go out.
Thanks to everyone for the tips. I checked the fuses and they were OK, so I took the dash out. There was a connection that was soldered to the printed circuit board on the back of the dash, and it had pulled off from the board. I resoldered it and checked the other connections. Lights are working now.
Thanks again.
BlindSquirrel
