Dash Lights
Xstream_1
South Boston,VA
The dash lights went out on the Cuda the other night and I noticed that one of the sockets had fallen out. Would that cause all the lights to go or is it sonmething else?
i would say it has to be something else. one bulb can be out and it should still work socket or not. replace it and see what happens...
I checked the fuses again tonight. It was blown on the end where you couldn't see it. Everything works fine now just need to figure out why it blew.
Thanks
X
glad to see you got it fixed. something must be loose somewhere. check where the bulb fell out from to see if something bumped the circuit board and maybe knocked the bulb out as well.......
i bet you were speding around like i do and after all this time it got old and loose and finally fell out. as for the fuse regulator on its way out? or maybe it was an old fuse, im normally not one to debate unless im sure, but thats my 0.02
Cerwin
