Thanks guys...
For the most part I'm not concerned with the interior, but I wanted to get some decent gauges and a stereo in the car. The rest of the interior will get attention when I'm done with the driveline. I have '74 Charger buckets and a factory Dart floor shift center console to install:thumblef: .
I used VDO Vision Series gauges (Volt, Oil pressure, Temp). There is a matching tach mounted on the left side of the steering column (you can see the needles if you look REAL hard between the steering wheel spokes). My factory amp gauge is not used, and the factory temp gauge didn't work worth a crap.
I didn't really NEED the switch panel, but I wanted more of a "business" look to the interior. One is for my fuel pump and one powers my gauges (and supplies near-true battery voltage to my volt gauge). The third will be for my electric fan override (when I get the fans installed). The fourth is just there because it's always good to have room for future expansion.
