The instrument panel and glove box will need to come out. There are 5 studs welded on the caps underside. Those nuts are 3/8 or 7/16 ( i forget ). Then about half way down each side of the turned down portions there is a sheet metal screw requiring 1/4 or 5/16.
I suggest starting at the right side. A search here should find threads containing pics. Good luck. Dont forget to remove the neg' battery cabel before pulling the inst' panel.
