dash paint
tkoboat
Active Member
Can anyone help with the satin texture paint on the dash and steering colum
Thanks T
Had my dash powder coated....haven't done the column yet
SEM products at your local automotive paint store. Be sure to use Bulldog adhesion promoter first!!
I use SEM, Its laquer so you mix it 1:1 with thinner. Works well. Spray a few coats then bring the pressure up a bit and stand back a little more to give the last coat some texture.
You shouldnt need an adhesion promoter on metal parts but bull dog is great for plastic and vinyl.
The factory called whats on the dash a swede finish. There have been numerous threads and responces concerning reproducing that finish.
The correct color can be a challenge. Try searching for those previous threads. Good luck
That looks awesome. Thats the ticket
Thanks T
