single wire coming out of the reverse light under the dash goes directly to the firewall connector, and I believe it is the connector that the windshield wiper wires are in. The light housing is the ground, so only one wire. Hope that helps. Oh, on the engine side, the wire jumps from the wiper harness to the reverse light wiring.
