None of them claimed it was going to be cheap. Only stock type modified parts.They could have used a 360 head with a 1.88 valve and not spent all that time turd buffing.
Its crazy to tell everyone you are on a budget and you want to make power and then use heads like that and then port them.
Thats cRaZy
Take this as a learning experience nothing else, stop with the 'should have used'
Let them "experiment"sit back and laugh,I‘m asking because I don’t know. What exactly are we learning?
Yup, there seems to be way too many neanderthals and they always want to argue especially on the internetUncle tony finally realised HE couldn't build a 318 that would even stay together at stock power levels, and in a rare genius moment, he managed to get at least 3 OTHER people to do the actual work and provide parts, as he sits back and makes money off the neanderthal types that watch his dumbass channel.
Yep, I figure those 302 heads will end up on the engine also. this build will stray way off the original claim made by Tony in video 1 of MI 318. And its mainly because Tony ran his mouth without knowing what he's talking about. If 318s could be affordably made to run at 300 HP, it would have been figured out way back in the 80s..the guys dicking around today are just wasting time., grinding up good 318 heads that maybe someone will need in the future...they say your average home porter screws the heads up to a point where they are inefficient and they don't even know it...
They should have used an LS.........why bother with a Chrysler engine at all. **** even a Tesla would be quicker.....Take this as a learning experience nothing else, stop with the 'should have used'
It's not that 302 heads suck it's that there's better choices for most builds and most aren't gonna port their heads.Nothing like a 302 head thread to bring out all the haters. Let me assure you those heads are still tiny but they manage to flow a lot for their size or lack there of.
I am just curious on YOUR thought on this. On a 318, do you like a fresh stock 360 head or the unported Speedmaster head.EXACTLY. If someone comes to me and says they want to build a 318 and port some 302 heads I will tell them to get their head screwed on straight and use a set of 360 head and leave the grinder alone.
Unless you are Running Super Stock or Stock eliminator you leave those castings alone.
Unless you like wasting your time behind a grinder to end up with less than if you started with a better casting.
It’s just stupid using those heads.
Only build I could kind of see them on is a 273 but even then probably still worth going 360 like 66fs does.EXACTLY. If someone comes to me and says they want to build a 318 and port some 302 heads I will tell them to get their head screwed on straight and use a set of 360 head and leave the grinder alone.
