I need to pick some brains here, mine is shot at the moment.
I'm getting no fire on cylinders 2 and 4.
I pulled all of the spark plugs and tested cylinder compression, every single cylinder is within 3 pounds of 140.
I have not done a leak down test yet, but the leak down tester has been ordered.
I put spark plugs in number two and four spark plug wires, grounded them and had my wife turn the key. I am getting strong spark from both.
Any ideas on what I'm missing? Other six cylinders run fine, just two dead cylinder side by side that have compression and spark. Any reason why those two cylinders wouldn't be getting fuel? I don't see any other signs of bad gaskets, no backfires, no pressure bleed between the two cylinders that I can see..
Got to be missing something here??
