68383GTS Well-Known Member Joined Nov 15, 2007 Messages 7,506 Reaction score 956 Location East Peoria,IL May 12, 2013 #1 It it OK to wax my car before I apply side stripe decals? Or does it matter? Thanks,Jim
68gtxman I used to reMember Joined Jul 11, 2011 Messages 5,090 Reaction score 4,389 Location Eastampton, NJ May 12, 2013 #2 Do not allow wax under any decal. It will cause you many problems. I don't even wax my decals after they have been applied either.
Bad Sport HALF A BUBBLE OFF Staff member Legendary Member Joined Jun 12, 2010 Messages 44,805 Reaction score 34,743 Location The Wolverine State May 12, 2013 #3 I certainly wouldn't. Just my 2 pennies.
68383GTS Well-Known Member Joined Nov 15, 2007 Messages 7,506 Reaction score 956 Location East Peoria,IL May 12, 2013 #4 That is what I thought.Buff the car with compound apply the side stripes and then wax. Thanks,Jim
jos51700 Green Bearing thread connoisseur Joined May 24, 2009 Messages 7,780 Reaction score 3,485 Location Bel-Ray May 12, 2013 #5 You actually want to use a Wax and Grease Remover before you apply the decals.
68383GTS Well-Known Member Joined Nov 15, 2007 Messages 7,506 Reaction score 956 Location East Peoria,IL May 12, 2013 #6 The car has not had wax on it in 20 years.But I am buffing it out.
2darts Well-Known Member Joined Jan 5, 2010 Messages 1,595 Reaction score 122 Location Ottawa May 12, 2013 #7 You can buff it,then clean the area with rubbing alcool where you are installing the stripe. I uses 50/50 water n alcool. If the stripe is a Matt finish, do not apply wax on them. If they are gloss you can apply wax on them.
