Deep oil pans
AdamR
Big Member
Bethel, CT
Anyone running a Moroso or Milodon deep pan ? Wich pan fits better ?
I have a Moroso 10" 8 qt. on a 360. It turned itself into a 9" first time out. But held up after it meet the pavement. Fit and finish was fine on it, just a little deeper than the road wanted. No problems now.
I have a milidon 8 qt pan and it works fine - putting it on I had to grind a lip off ther back seal area because of my block plate (minor prob) . Ihave only smacked it once and you cant tell (tough sucker)
i had a moroso pan, removed it after it bottomed out and it took out one of the welds and started leaking, got it fixed and it it bottomed out again, that time it got a bigger hole... put the stock pan on, didnt want to deal with that in my daily driver... wouldnt recommend these unless you use it at the track only or know your not going to bottomg out, which is pretty hard unless miss cleo is with you
I have to say as Tony said only difference is I have a moroso 8qt.
been on car for 6 years ad not a ding in it =D> yet.
