Demon quarter to tailpanel seam pic?
Demonic
Mid Atlantic
I figure this is a long shot - anyone have a picture of an untouched, factory seam where the tailight panel meets the quarter, under the lead? I'm looking at the stamped offset in my wonderful repo AMD quarter. There appears to be multiple pieces. The tailight panel was previously repaired, so it's no help.
This is the only pic I have of my tail panel after removing the lead and drilling the welds out. Hope this helps you out.
Here's the right & left sides. Hope you can zoom in for a closer look at the connection.
Thanks for the reply, but I need a close up that shows the detail of the panel overlap for a Demon. The 73-76 Duster is a bit different. Nice wheels, BTW!
Tons of pictures in this how to thread
Duster to Demon Tail Panel Swap
As for the later Dusters being different they are, but, not at the quarter to tail panel seam. Tail panel to trunk pan yes, and tail panel to rear support brace yes, but the quarter to tail seam at the edge of the quarter is pretty much identical. The little corner pieces that connect the rear support to the quarter are different, but not the tail panel. Otherwise I wouldn't have been able to put a Demon tail panel on my '74 Duster.
