Destroked Small Block?
harrisonm
Topeka, KS
I had a friend who had a 69 Z-28. It was a great car, it was pretty fast, it sounded good, and it revved up nice and high. At 302 cubic inches, I believe it was just a destroked 327. I realize that people build stroker engines for more cubes, torque and HP. I was just wondering if there was anybody out there destroking Mopar engines. Other than higher revving (if that is, in fact the case), would there be a reason to?
Those engines were homologated (see how I worked that big word in?) for the TransAm road racing circuit in the late 60 and early 70s. Small cube, high revving engines were what was needed to keep the cars under power good coming out of turns. I would just guess the same holds true for road racing today. Might see if autoxcuda will chime in. I am sure he will have more to add.
@autoxcuda
Yes. The reason to destroke an engine is to fit into a cubic inch limit class. This is mostly found in NASCAR with there 355 cid limit. There are some drag racing classes that limit engine size by cubes. The rules that I have read in the past were small blocks to *** size, big blocks to *** size, etc... but that was stroking up. The old Trans Am racing series had a 5.0 liter limit.
How you get the cubic inches long s a matter of bore and stroke and there is nothing in the rules about you having my to (must) run a certain configuration.
MoPar used to sell destroke cranks for this purpose. 1 such kit was to destroke a .030-360 engine down to a 352. Currently Mancini racing has these forged cranks on sale. You’ll need a custom piston. Mopar had forged slugs for this.
The ability to rev high is mostly a valve train stability & valve spring issue. Not so much the cranks stroke. The idea of a shorter throw on a crank needs less time to cover the distance so yes, it revs quicker. If everything else is equal. A shorter throw on a crank coupled with heavier rods and pistons will not move as fast (or easy) then a longer stroke crank and super light rods and slugs.
I have a destroker crank, rod, ring and slug set from MoPar. If I get a suite able block to run it, I will.
@autoxcuda
Like was said trans am had a 5.0 liter class. There was also a 2.0 class.
These factory sponsored high dollar race teams could afford to rev these motor to get the most out of thier designs. And replace valvetrain and go through them constantly.
I run a stroker cause I don't have a cubic inch limit, can't afford the high dollar valve train and related parts to safely run high rpm's. And most of all I'm not a pro racer and don't have a pro maintenance budget.
It's just a cheaper in the short and long run to get to a higher 450-550 HP level with the stroker.
The '70 mopar 305 motors were reportedly 460 hp at beginning of season, but devoloped some more as season progressed. And they blew motors in practice and in races.
I could be close to 460 hp with my budget built 416 that doesn't have to spin past 6200.
And my car is not in a scratch built 100% dedicated gutted rollcaged race car. I've got more motor than chassis and driver.
I agree mostly to fit class rules the hemi was destroked for nascar to 305 in the end.
But stroke and engine size don't really decide engine potential. Heres where people usually confuse hp and torque as 2 separate things.
The ultimate limit of an engine is bore size, cause it limits intake and exhaust flow (valve size and it interaction with the bore).
But the true limit of a sbm is that it comes apart somewhere after 600hp so in that way 318/340/360 have the same limit or potential.
If the rotation assembly is made from the same material at the max piston speed limit (redline) for each stroke 2.96/3.31/3.55/3.58/3.79/4 etc.. will have the same power potential for a given bore.
Cause it will br able to pump the same cfm (hp) through the engine.
But since you can't keep the same rod ratio for each the short ones will eat a bit of power due to friction.
Torque is basically power per one powerstroke and hp is all the powerstroke added up over time (rpm).
500hp is 500hp doesn't matter how you divide it up between torque and rpm as long as geared right both can to the same job.
Performance wise.
Bigger engine have obviously advantage on the street. Better street manners needs less gear and stall more reliable etc...
On the track that doesnt matter much. If a high revving short stroke long rod gives you a slight advantage in a highly competitive class then its worth it or is able to make it to the end of a 500 mile race over an engine slightly more but less reliable than its worth it.
Thats why we got to be careful of some of these race theories that come from the racing world dont always mean much in the everyman street car.
The destroked 426 hemis didn`t work worth a flip either ! Just another way to kill the mopar winners !
In 1981 John Hagen and Charlie Malyuke were running destroked "baby Hemis" based on low deck big blocks to be more competitive under NHRA's lb/cubic inch Pro Stock rules. It was basically a 383/400 with the block heavily modified to accept the Hemi heads. Hagen set a MPH record and I believe got R/U at the NHRA World Finals in 1981. Considering the short development time, it would have been a very competitive combo if the rules hadn't been changed for 1982 to 500" limits for all brands.
The NASCAR teams only attempted a 366 Hemi.
The 305 motor were small block left over '70 trans am motors from Keith black that were sent to Mario Rossi's #22 team for the beginning of 1971. Only used in a few superspeedway races in Daytonas.
Nascar did have some larger destroked Hemis over the years. 390 something also sticks in my mind, but that may have been in drag racing and/or Nascar.
But one of my favorite "destroked" stories is when Dick Brooks almost won a race (Daytona?) with the basically 305 Trans-Am small block in his Daytona wing car.
The way I look at displacement is static and dynamic. Static is what it is measured out non running eg. 340 360 440 etc....
Once running the displacement is basically dynamic. A 360 vs 402 becomes (cid x rpm)÷ 2 but that number is meaningless.
Cfm is something more relatable.
So that carb formula can be used.
(Cid x rpm) ÷ 3456 = cfm
402@6000 = 698 cfm
360@6700 = 698 cfm
You can see both are able to pass the same amount air/fuel and have the same potential hp at those rpms.
Or an easier way to calculate. Since it doesn't really matter the cubic feet or inches per minute.
You can do it this way (cid A x rpm) ÷ cid B = comparable rpm, 402 x 6000 ÷ 360 = 6700
Charley's 383 based Hemi. I believe he was working for Gary Ostrich at the time.
I just delivered a small block 2.96" stroke billet crankshaft to my machine shop that was custom made for me by Bryant Racing in Anaheim, CA. This 305 will be the "street" motor for my '72 BBody project car.
i will be using factory correct '72 Thermoquad and '72 cast iron intake manifold. An almost copy of the 1968 factory spec 340 (manual) hydraulic camshaft, custom rods (longer than stock), and factory 340 open chamber cylinder heads (2.02 intake valve). The old school 12:5 to 1 domed TRW (L2322F) forged pistons will only provide about a 10:5 to 1 compression ratio due to the loss in compression inevitable when de-stroking. I hope horsepower will equal the factory 340, obviously torque will be at a loss.
340 @ 5000 rpm = 492 CFM
305 @ 5600 rpm = 494 CFM
Build thread (305 motor not included yet):
Introducing "Project Odyssey" a 1972 "Super Satellite"
Rod are 6.298" center to center (vs 6.123" factory stock)
I always heard the cylinder head dictated the HP potential and the stroke dictated the torque curve. Like a 170/198/225. All had the ability to make a measly 145HP but who would get there first? "HP=HP no matter how you devide it up" is true..., you can make a high revver but have little to no useable torque. Look at a Hayabusa Motorcycle engine: 85 hp at 85 ft/lbs at 5250. HP keeps going up to 180 at 10K but the torque stays flat at 85. Whats the saying.."HP sells cars but Torque wins races"?
Another food for thought.... thought...
MoPar sold 3 different stroke destroker cranks to fit the 355 cubic inch rule for the small block. Short track, medium track, super speed way tracks.
What's the reason you chose to do this? It's interesting, I'll give ya that
Engine A 1st gear 2.5:1 x 4:1 = 10:1
dyno.................................. track
rpm/ Tq/ hp..........mph/ tq ground/ Hp ground
2500 381 181 21 3810 lbs-ft 181
3000 403 230 24 4030 " 230
3500 415 277 28 4150 " 277
4000 438 333 32 4380 " 333
4500 437 375 36 4370 " 375
5000 416 396 40 4160 " 396
5500 389 407 44 3890 " 407
6000 344 395 48 3440 " 395
4029 lbs-ft average
Engine B 1st gear 2.5:1 x 5:1 = 12.5:1
dyno ..................................track
rpm/ Tq/ hp......mph/ tq ground/ hp ground
3500 272 181 23 3400 lbs-ft 181
4000 302 230 26 3775 " 230
4500 323 277 29 4038 " 277
5000 350 333 32 4375 " 333
5500 358 375 35 4475 " 375
6000 347 396 39 4338 " 396
6500 329 407 42 4113 " 407
7000 296 395 45 3700 " 395
4027 lbs-ft average
1st of all torque and hp aren't two separate abilities.
hp is torque combined with rpm.
You can't separate torque and rpm, a running is always doing both.
Yes torque moves your car but not without rpm. Which is hp.
Think of it this way torque is a snapshot of one powerstroke.
One powerstroke ain't gonna get you too far but them all added up over time (rpm)
Now you got hp, the combined ability of rpm and torque to move and accelerate your car.
Heres why your engine torque numbers isn't as important as your hp numbers.
For one the torque numbers are part of the hp numbers plus only tells you whats happening at the crank,
not whats getting to the ground through the tires and the rest of the driveline.
For the future eg. this driveline loses zero hp through friction etc...
1st of all gearing only multiply or divide torque and rpm not hp. hp will always be constant.
1st eg. 200 hp @ 4000 rpm has 263 lbs-ft @ 4000 rpm also.
If you put it through 4:1 gears torque will multiply by 4 to 1050 lbs-ft, which is 1050 lbs-ft divided between two tires
to the ground.But instead of spinning 4000 rpm the rpm is divided by 4 and now the tires rotate 1000 rpm. Which is
1000 x 1050 \ 5252 = 200 hp.
2nd eg. if you look at both engine dyno above you'll see Engine A powerband goes from 2500-6000 rpm and Engine B powerband
is a 1000 rpm higher, 3500-7000 rpm. Engine A and B make the same hp but B does 1000 rpm higher and A makes more torque.
Obviously A is bigger displacement, and yes more streetable needing less gear etc.. but thats not point, both have same
potential even though A has more torque which I'll show it don't matter as long as there geared right.
Both engine have same 1st gear of 2.5:1 both are in same cars with same weight traction etc... But different stalls and gears.
Engine A has 4:1 and B has 5:1. If you look at hp to the ground is the same as the engines. If you look at torque and mph it verys
a little. But if you look at average torque to the ground pretty much identical A 4029 lbs-ft vs B 4027 lbs-ft.
Both Engines are pretty similar performance wise. Torque doesn't matter as much as hp as long there properly geared.
Engine A has the obvious advantage for the street not so much cause of torque but cause it makes low rpm hp.
Engine A was a 360 and B would be mathematically a 305 mopar.
[Qi have a 2.96 stroke moldexUOTE="rumblefish360, post: 1971917454, member: 1189"]Yes. The reason to destroke an engine is to fit into a cubic inch limit class. This is mostly found in NASCAR with there 355 cid limit. There are some drag racing classes that limit engine size by cubes. The rules that I have read in the past were small blocks to *** size, big blocks to *** size, etc... but that was stroking up. The old Trans Am racing series had a 5.0 liter limit.
I have a destroker crank, rod, ring and slug set from MoPar. If I get a suite able block to run it, I will.[/QUOTE]
i have a 2.96 stroke moldex crank for sale,destroked 318 diamond pistons,a 70 318 block if anyone is interested,was going to destroke a 318 to a 288
Torque moves the load but HP gives you speed....
There is no such thing as HP. A dyno does not measure HP it measures torque. HP is the mathematical outcome of a formula with torque and RPM
HP = Torque x RPM ÷ 5252
Notice the constant 5252? It forever locks HP and torque together.
Z28 engines were "nothing special." They were a bunch of parts Chevy threw together. "Us kids" used to bore a 283 and call it a 301. (It is something like 301.7) Chevy did that and called it a 302
327 block= 4.00 bore, 283 crank gives you the stroke, and the infamous "double hump" "camel hump" heads, plus a hot cam, hi rise, etc.
Chev played the same game with the 307....283 bore block, and 327? stroke crank.
