I'm in the final stages of putting my 68 Dart GTS back together. I moved the springs back to center the rear axle in the wheel opening.
How far does the front yoke need to stick into my 727??
How much slack do i need between the end of the drive shaft u joint and the rear end?
How much is to much slack between the rear u joint and the rear end?
Thanks,
Jeff
Thanks,
Jeff
