Dexron and ATF3
racingsnake440
Hi, is ATF3 compatible with Dexron? I've checked previous posts which say which fluid people are using but I couldn't find one that says if the two fluids can be mixed.
Thanks
I would use one or the other, but I wouldn't mix them. My
recommendation would be for you to use ATF+3 if it is an older non-lockup style.:salut:
