ramcharger
Dismember
OK, here's the build in my Ramcharger:
360 LA block bored .040 over
Block decked for zero P to D height
Stock crank turned .010 under
Eagle I beam rods
KB hyperutectic flat tops
Cop car heads milled to 68cc, 2.02 intakes, pocket ported by me.
10.2:1 measured comp ratio with a Cometic .040 gasket with 4.100 bore.
Lunati Voodoo Cam:
Advertised Duration (Int/Exh): 256/262
Duration @ .050 (Int/Exh): 213/220
Gross Valve Lift (Int/Exh): .454/.475
LSA/ICL: 112/108
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1000-5500
Part Number: 60401
Crane Gold 1.6 Rockers and shafts.
Crane springs, retainers and locks. I can't get the specs as they have been taken over by S&S Cycle (Not a bad thing in my view), but the springs were installed as recommended by crane with a IIRC 110 lbs seated and 300 lbs @ .500 lift.
Weiand Action+ Dual Plane Intake manifold, no spacer.
Holley early (no power valve on secondary metering block) model 4777 4150 style carb 650 double pumper.
Here's my tuning specs:
12 degrees intial with 34 total all in by 2500 rpm (MP distributor).
Ran it with the vacuum advance, but I disconnected it as pedal feel and cruise pedal position was not affected.
I am running a .032 primary squirter and .028 secondary squirter.
74 primary jets and 76 secondary jets.
OK, here's my driving impressions. Absolutely stellar off-idle and highway passing performance in a 5500 lb full time 4wd truck at 5900' altitude. If I floor it going up a hill @ 6000' + and slap into 2nd at 70 it just freakin' moves and lets out a howl that makes people freak, lol! But here's the deal, it starts to lay over @ 4800 and does the "snap, crackle, pop" at about 5000 rpm.
Lunati says this cam is good to 5500, but this is, of course, an LA cam that spreads the spectrum from to 273-360 ci. I think it's valve float.
Here's the question:
I had a Comp XE262 in a lower compression (stock) 360 with their recommended springs and installed as recommended and it did the same thing. Am I asking too much on the top end for such a small cam in the rare air here? Should I just quit my complaining and just keep smokin' every Chevy/Ford/Toyota pickup that comes my way? Should I swap to Lunati's true dual springs as valve float may be my true problem? Am I insane for blasting my full time 4WD Ramcharger to 100 MPH on the entrance ramp to figure this out? Muwhhahahaha!
Eagle I beam rods
Lunati Voodoo Cam:
LSA/ICL: 112/108
Part Number: 60401
