did a mock up on the old duster build
earthmover
in the tire smoke
nc
run down on the build
340 bored 30
j heads little work flow 240@500/140@500
I have 2 intakes x-cel and torker 340 thats matched to the heads(x-cel will be on top I think)
bme dome tops that 17thous out of the hole on eagle h beams
hv oil pump and a mild deep pan and pick up
steel crank bal.
950 hp carb
I have small tube headers and big 1 5/8 and a set of 1 7/8 (1 5/8 on this I think for low end)
727 rev trans deep pan
9 1/2 dyn verta
4.57 gears in 489 case
8 gal cell
mp drag shocks back and comp adj in the front
all in a 70 duster
I took pic of the mock up but dont know how to post so if anybody would I will email them to you ..
I plan to get a new cam and lifters the Bobby told me to try out (Thanks Bobby still plan to send the other heads out to you)
I plan to use the timing ten. this time cause I had to much slack int he chain even with the one for hone blocks....(gear drive in the years to come)..
But I installed the bearings all oiled up then the crank oiled up and caps man this thing spin so free buy hand...but I checked the piston in a few diff. places and got this # if they mean anything to you guys (flat part of the piston is 17 thous. out of the hole/center of the piston is 16 thous. where it goes down from the flat to the val pocket/ the dome comes out of the piston a total of 345thous to the top at top dead center if I meas. right..I have to find my notes on the deck height and pin height of the piston then we may can come up with a comp. I know the heads are 65cc I think thats right its on my other notes also..sorry so long just glad to be working on this thing after about 2.5 yrs down....but if anybody would post pic please let me know thanks.........oh if you have ? please ask as I would love all input :cheers:
If the whole piston is 17 thou out of the block, you better check the quench area of your heads to make sure you have enough clearance. Did you have your block decked a bunch? Is the piston supposed to be positive decked?
so the flat top of the piston measures .016 or .017 thousands out the deck..that is fine...the dome is .345 thousands out of the deck...
you have open chamber heads....that fine...
put the head on the block without the head gasket ...turn engine over...if the pistons does not hit the heads....good...
get a head gasket with the thickness you want to use...that will be additional piston to head clearance.
oh yea the piston to head clear just fine I just need to figure the comp for the motor now..I use to use the 1008 worked good. but I ran 110 in it and I want to know if I really need 110 or could I run the pump......also plan to go diff. on the cam this time....
