Did LA water pumps ever get fine thread bolts from the factory?
Johnny Mac
www.blueprintengines.com
FABO Vendor
OHIO
One of our friends in the business, caught a shipment of LA water pumps, with fine thread 5/16 - 24 fan / pulley bolts, vs 5/16 course. Was this ever a factory thing? OR just a shipment of mis tapped water pumps?
I hadn't heard of it, but figured you guys would know!!
Luckily they weren't our pumps. Lol
I found this old thread...but nothing difinitive.
La fan blade bolt threads fine???
I never ran across a factory pump that had fine threads for the fan bolts.
I "think" some setups had studs, but they were USS into the pump flange, and fine out on the forward end of the studs
me either! So i'm wondering if some parts manufacturer simply tapped the wrong threads, or some odd duck A/C truck with heavy duty cooling had them, or something to that effect. Thanks!
So double threaded studs (like a rocker arm stud?) with course into the pump flange, and fine there outward.? that sounds vaguely familiar....I'm almost recalling that on a viscous fan setup I had, but i suppose I could be remembering wrong. Probably 20 years ago.
All the OE stuff I remember was coarse thread. All the aftermarket stuff I’ve used lately is fine thread.
I don’t know why the change. It’s irritating for sure.
any rhyme / reason you can share please?
Early in my career at a dealership, I had taken a box of 5/16 coarse bolts to work cuz I had busted out of my flat rate twice cuz I had to stand in line at the parts counter waiting for 4 coarse thread bolts to replace the fine thread bolts I took out. Used a few outa that box thru the yrs.
Never forgot it, - on reflection, they may have been polys, they used the same pump.
But I do agree, after a few years, they were all coarse .
Your memory is correct, as Del mentioned, a fine/coarse stud was often used
