chubby
Active Member
I am setting up my pinion angle and just thought I would check the angles with
you guys before I weld it up.
Diff is down 2 degrees trans is down 11/2 degrees with what I can work out this gives me a pinion angle of 31/2 degrees down.Would that be ok for a stock leaf car with one added extra spring
