Difference between 67-68 and 69 Cuda Grill
Each year is completely different. Yes the 67 and 68 will interchange pretty easily, but they are not even close to the same.
69 is it's own complete animal. Even the tabs on the fenders for the headlight close out rings are different.
What is the difference between the 67-68 grill and the 69 grill? are they interchangeable?
Plastic vs. metal and shape. The earlier grilles/surrounds will not fit the '69 header or vice-versa.
If by chance it is what you are leading up to, one can fit an earlier setup on a '69.
You'll need the earlier hood, header, and grilles/surrounds I do believe.......
