Dimensions of factory Rallye Wheels?
DustyEd
Far Out, USA
We are needing to know what the rim width and backspacing was on the small bolt pattern (5x4) factory original Rallye wheels for the 1970 A-bodies (Duster). Also, has anyone mounted the G70-14 tire on these rims without any issues? And if so, does it look okay?
Rim width is measured between the beads with no tire. Factory SBP Rallyes were all 5.5" wide.
Well, we went with the GoodYear Polyglas RWL G70x14 tires on new 7x14 Rallye Wheels with 4.25 backspace (made by Specialty Wheel) on the rear of our 95% original "blue collar" '70 Duster 340. This rear tire and wheel leaves a strong 3/4 inch clearance to the stock HD leaf springs. (Sure happy we didn't go with 15" on the rear, because the 14's fill the side profile of the wheel well just fine!). We also put E70x14 on 6x14 Rallyes with 4.0 backspace on the front. Wow, we really like the appearance of this combo. We will try to get a side photo posted, so everyone can use it as a reference.
