Sirsmiley9
Can’t seem to get my dip stick tube to go in straight because of the fuel block off plate on the 360 magnum any one else run into this/have a solution
You can see it doesn’t go in quiet straight and that’s with a bolt without a lock washer or anythingA picture might help,
I can’t remember what year exactly but some I think 2 years had a fuel pump added and the la timing cover is the same sizeFYI: Magnum 5.9 blocks do not have a provision for full pumps. Yours in a LA 360 block. However, demonracer has the answer to your issue. Good luck.
