synchro66
I have a chrome dress up after market dipstick on my 360SB dipstick reads FULL (cold) but i drained the oilpan and only have 3 litres in it?? any ideas??
No idea since I don't know a liter from an asshole. Talk to me in quarts like the engine came with and I might can help.
Thanks for adding information that should have been included.A liter is a little more than a quart...
3.8 liters = 1 gallon = 4 quarts
Take it easy, this fellow Fabo member is reaching out from Australia. I bet his Mopar has the steering wheel on the right and the manual probably mentions Litres, not quarts.No idea since I don't know a liter from an asshole. Talk to me in quarts like the engine came with and I might can help.
I know he is. But he's reaching out TO a forum made up mostly of members in the USA. It helps if we don't have to take the extra step of looking up a metric conversion. Besides, I did come back and offer him good solid information, but of course, you cherry pick the negative.Take it easy, this fellow Fabo member is reaching out from Australia. I bet his Mopar has the steering wheel on the left and the manual probably mentions Litres, not quarts.
That's all I was doin. We gotta poke the stick at each other sometimes. lolI know Rusty. Just busting yer balls a bit.
I hereby decree, a litre and a u.s. quart are fn close enough to consider them the same. It ain’t rocket surgery.No idea since I don't know a liter from an asshole. Talk to me in quarts like the engine came with and I might can help.
I agree with that now I know the difference. I didn't before.I hereby decree, a litre and a u.s. quart are fn close enough to consider them the same. It ain’t rocket surgery.
Can’t buy a quart of anything here in canada, and every dipstick says add 1 quart. Unless its a transmission, wtf is a pint?
Cant buy a pint of transmission fluid anywhere…and zero bottles are marked with pints..
Whatever you say, Steve.Why the hell does a conversion table need to be included? Too simple to now a little and a quart are basically the same? Ohhh cuz if it's not, it's a reason to be a condescending wiseass. I get it now...FFS
Your understanding of the system is flawed slightly. You're correct not to trust aftermarket.... But ALL dipsticks need to be calibrated.Do not trust anything aftermarket. Compare tube and stick length with OEM.
Easy peasy.
Park on level ground.
Put in the amount of oil the engine is supposed to be filled with, with the filter.
Run it for a few min to make sure the filter gets full.
Shut it off and wait 5 min so the oil up top drains back into the pan.
Pull the dipstick, wipe it clean and reinsert it.
Pull it out again, look at where the oil level is.
Make a new FULL mark.
Now you know where full really is.
I was pokin him with the stick and jokin around just like I said. Who was the one that purposely came in here stirring up ****? You like you always do. You're an ***. You're now on the list.You were arrogant/condescending in your response, now just twisting your arrogance around to make it look like its the OP's fault? BS
It's never easy to lengthen your stick.
That’s what she said…
You can "buy a pint" almost anywhere in the world- you're just not looking in the right places!Can’t buy a quart of anything here in canada, and every dipstick says add 1 quart. Unless its a transmission, wtf is a pint?
I'll take a British Pint over American Pint every day. 22 ounces British VS 16 ounces for USA.You can "buy a pint" almost anywhere in the world- you're just not looking in the right places!
As pointed out later in this thread. Not all gallons are gallons! younger Aussies are easily lost on Imperial measurements and even fewer realise the measuring system in the USA is actually pre Imperial. But I must admit I got a better heads up than most with 20 years in aviation, where you have a curious blend of US, Imperial and metric all in one place.A liter is a little more than a quart...
